Qos - Precedence in a policy map
cccnetwork1
Hello ,
I'll try to be brief  :
I've a number of class-maps , based on access groups , some of which are overlapping  eg  Proxy  ---- permit any to host 10.10.10.10
VIP - permit 10.1.1.0 /24
I want VIP to be dscp ef
Proxy  to be  dscp 33
Policy-map xxxxxx
class VIP
set dscp ef
class Proxy
set dscp 33
if a host on 10.1.1.0 talks to proxy 10.10.10.10  which dcsp value is assigned ?
i know I could add a further class-map match all  , but this is a small example for a compliacted scenario .
when a packet could be in a number of classes is there a firstmatch / bestmatch  , and does this then continue to policy-map positioning of class
Any advice would be much appreciated .
John Blakley
The classes in a policy map are matched in order. For example, if you had the following:
class HTTP
permit 10.10.10.0/24
class HTTP-Dif
permit 10.10.10.10/32
policy-map Web
class HTTP
set dscp ef
class HTTP-Dif
set dscp default
The 10.10.10.0/24 subnet will be set for EF and the host 10.10.10.10 wouldn't match the HTTP-Dif. To fix that, you would need to remove the policy-map from the interface and rearrange your class maps:
policy-map Web
class HTTP-Dif
set dscp default
class HTTP
set dscp ef
Now the host will get the appropriate marking, and what doesn't match in the 10.10.10.0/24 subnet will hit the HTTP class.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Hi John
Could i ask a favour ?
I am involved in a thread where a guy is having problems with routing. The thread is quite long and i think we have found the problem with his setup but the only way to fix it (that i can see) is to do a sort of conditional route advertisement with EIGRP. There may be another way that i have missed but if not i was wondering if there was a way to use EEM to only advertise the route under certain conditions ie. when an 1841 router is actually connected up in this case.
If you have the time can you have a look and see if there is a possible solution.
https://supportforums.cisco.com/thread/2254631?tstart=0
Jon
John - thanks for that - could I summarise as marking depends on a first match in the policy map
Yes, that would be correct.
HTH,
John
