Bookmark
Subscribe
3024
Solar Winds Installation for Bandwidth Monitor
Hi Team
               I had installed Solar Wind Trial version for Monitoring the real time bandwidth. What i have fill in the community string if it selected snmpv1/2c and if we select  SNMPv3 we need to create credentialname, snmpv3username, snmpv3 context,authentication method and engryption method.
Both should be match in Network devices?
How to find the network devices for these parameters?
8 Replies 8
lmediavilla
I have a medium size deployment with solarwinds orion, I recommend you to use snmp read community version 2c, it's much faster to implement and all vendors implent it, including load balancers wan acceleators wireless controllers.
You have to manually each device
snmp-server community #communitystring# RO
Kind regards
its not working for me. It saying credential failed
any one?
lmediavilla
did you try witn version 2c? it works on my deployment fine
ya tried with snmpv2c only could u give snap shots for the same...
Looks like there is a typo in credentials.I do not have snpshot on V2 (converted to V3) but here are the details..
Orion:
SNMP Version : SNMPv2c
SNMP Port : 161
community string:
Read/write : leave it blank
Router/Switch:
snmp-server community RO
snmp-server host V2c
hth
MS
Did you try to send an smmpwalk to test if you can reach the device?
spreston2007
Are you trying to connect to windows box or a cicso switch?
