qos - priority percent question
dahua.huang
Hi, all cisco tech
one thing bother me for a while.
we have two point to point routers with a OC3 link and do not know who configured it.
policy-map WAN-EDGE
class AAA
  priority percent 65
class class-default
  fair-queue
  queue-limit 1000
interface POS1/0
ip route-cache flow
service-policy output WAN-EDGE
hold-queue 1000 out!
#show policy-map  interface POS1/0
POS1/0
  Service-policy output: WAN-EDGE
    Class-map: AAA (match-all)
      60 packets, 3144 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name brocade
      Queueing
        Strict Priority
        Output Queue: Conversation 264
        Bandwidth 65 (%)
        Bandwidth 100750 (kbps) Burst 2518750 (Bytes)
        (pkts matched/bytes matched) 5/520
        (total drops/bytes drops) 0/0
    Class-map: class-default (match-any)
      52048631371 packets, 10961955420222 bytes
      5 minute offered rate 3196000 bps, drop rate 0 bps
      Match: any
      Queueing
        Flow Based Fair Queueing
        Maximum Number of Hashed Queues 256
        (total queued/total drops/no-buffer drops) 0/4378877/1115152
Both side with same policy.
Here is my question.
Looks class AAA in LLQ with 65% bandwidth. and others using 35%.
1. Can regular traffic over 35% during high traffic ( class AAA in low traffic and not over 65%)
2. Class AAA with 65% means reserved and no one can using it? ( looks same question with one).
3. does queue-limit 1000 will cause delay becuase of hold too long.
Thanks.
Hi dahua,
You use QoS LLQ (configured with priority). The Class A has been configured with the priority command. The bandwidth is not reserved but can be used by the other classes when there is not congestion and Class A needs >65% bandwidth.
However, during congestions the traffic of CLASS A is policed to 65% and do not exceed this value in order to not saturate the link only the CLASS A traffic.
Yes the default class can exceed the 35% if the Class A is not congested and there is not need to use all the 65% of the bandwidth.
Finally, regarding the hold-queue for most other interfaces, queue length must not exceed 100.
The queue length value can be between 0 and 4096. The default value is 75
You can find detailed description to the next link
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml
Hope that helps!
Vasilis
thank you and it cleared my concerns.
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
"3. does queue-limit 1000 will cause delay becuase of hold too long."
That depends on multiple factors, including what's "too long", bandwidth, and queuing being used.
Since you're using FQ in class-default, the 1000 queue-limit would be of most concern in how long individual flow queues might be.  Since queue-limit is in packets, depends on packet sizes.
For example, 1,000 64 byte packets would take only about 3 ms on an OC3; and about 77 ms for 1500 byte packets.  Depending on your BDP, and since worst case is under 100 ms, with FQ 1,000 may be a non-issue.
