QoS query - filters within QoS
Angelo ANELLO
Hi Guys,
     I have the following QoS settings applied within our routers and was wondering if we could tweak it further.  Our settings are to prioritise Citrix and Printing traffic.  What i would like to know is if it is possible to add further priorities within just the Citrix settings.  As you can see, Citrix will encompass alot of traffic including our Email traffic and we would like to know if it is at all possible to achieve this.  Below is the current config and any assistance is greatly apprecaited:
class-map match-any Citrix
match access-group name Citrix-ACL
policy-map WAN
class Citrix
    priority percent 80
  set dscp af41
class class-default
    bandwidth remaining percent 100
    fair-queue
policy-map Global
class class-default
    shape average 2048000
  service-policy WAN
Service-policy output Global (applied to WAN interface)
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Just want to ask, your combined Citrix traffic won't exceed the allocated bandwidth?  Reason I ask, LLQ, if the interface is congested, will drop over-rate traffic.
Also, normally you only use LLQ for real-time traffic like VoIP.
Later NBAR can examine later Citrix for traffic subtype.  Allows you to tell the difference between Citrix on the screen vs. Citrix printing.  This then allows you to treat such Citrix traffic differently for QoS.
Hello
Exactly what are you intentions- at present the citrx policy is taking 3/4 of the link (1638400) with everything else using 1/4 (409600)
Can you post your Citrix-ACL
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Joseph W. Doherty
Disclaimer
Posting
