QoS question
jasonww04
I'm trying to give RDP priority over web traffic. This is what I have so far:
class-map match-any scum
match protocol http
class-map match-any RDP
match access-group name RDP
policy-map die-scum
class scum
   police cir 8000 pir 9000
     conform-action set-prec-transmit 0
     exceed-action drop
policy-map Inbound
class RDP
   police cir 9000000 pir 10000000
     conform-action transmit
     exceed-action set-prec-transmit 0
     violate-action drop
  service-policy die-scum
ip access-list extended RDP
permit tcp any any eq 3389
If I put the policy-map Inbound on my WAN interface as an input filter, it does nothing. However, if I put the policy-map die-scum on my WAN interface as an input filter, web traffic almost grinds to a halt (which is what I want).
What am I doing wrong here?
Edison Ortiz
You are only allowed to apply a policy to an interface and you have two policies.
Ideally, you should have this configuration:
policy-map inbound-internet
class scum
     exceed-action drop
class RDP
      violate-action drop
interface WAN0/0
service-policy in inbound-internet
Edison
Edison Ortiz
class scum
     exceed-action drop
class RDP
      violate-action drop
interface WAN0/0
Edison
The service-policy die-scum in my policy-map Inbound doesn't run the policy-map die-scum as well?
policy-map Inbound
class RDP
     violate-action drop
That feature requires an IOS that support HQF
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/qos_frhqf_support.html
For other IOSes, you are limited to class class-default on the parent class.
Edison
Thanks for your answers. I tried it the way you suggested and it worked.
