qos rate limiting
rajath4444
Hi All,
I have a specific requirement .
On a 5 Mbps link - rate limit voice traffic with 3 Mbps and other traffic to 2 Mbps.
And whenever we donot have any voice traffic assign complete 5 Mbps to other traffic.
Can someone please help me in choosing the best QOS mechanism to accomplish this request.
6 Replies 6
siddhartham
Level 4
Level 4
You can use MQC and configure somehing link below to achieve this
class-map match-any voice
match  dscp ef
class-map match-any signaling
match  dscp af31
policy-map qos
class voice
  priority percent 40
  set ip dscp ef
class signaling
  set ip dscp af31
  bandwidth remaining percent 20
class class-default
  set ip dscp default
  bandwidth remaining percent 80
service-policy output qos ----- on your outgoing interface.
QoS is a end to end config, your service provider should honour your markings other wise they wont carry over.
Siddhartha
Siddhartha
In addition to what Siddhartha has recommended:
policy-map PARENT
  class class-default
  shape average 5120000              <<<<< Rate limit your link to 5Mb
  policy-map qos            <<< This is the child policy specified in the above post.
int XX -- Outgoing interface
service-policy output PARENT  <<< instead of applying the policy qos as mentioned in the above post specify PARENT, it will apply both.
Also you under you class maps you can also add some other criteria as well for matching the traffic (ACLs, protocols etc)
Hope it helps!
Terry
     Please be keep in mind that only 75% of the bandwidth is available by default on your wan interface so you should take this in consideration when desiging different classes and QOS policies.  You can change this behavior with the max reserve bandwidth command on the WAN interface and change it to 100% which basically tells the router that 100% of the bandwidth is available for allocation.  However, depending on how congested this link is at times you could potentially mess with routing protocol updates and cause circuit flaps if too many of the hello messages are dropped.  This is what the 25% was originally reserved for along with other "router type" traffic.
You might be thinking that 25% is a lot to reserve for hello messages and such.  I would tend to agree which is why I see so many configurations nowadays that make a special class for CS6 which is where your protocols run.  Give that class just what it needs.
But as Siddhartha pointed out QOS is end-to-end and you really should check with the provider on what type of QOS markings they honor.  Many ISPs only honor a few different classes.  If this is a point to point then its a moot point (no pun intended)
- Mark
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Note: that's true with pre-HQF CBWFQ; HQF changed some of the "rules".
Also note: re: "reserve" - CBWFQ bandwidth setting sets a minimum guarantee.  I.e. unused bandwidth is available to other non-LLQ classes.
I stand corrected.  I didnt see the bandwidth remaining part and thought it was bandwidth percent only.  Your correct about the pre-HQF.
Joseph W. Doherty
Disclaimer
Posting
Device?  IOS version?  Interface type? WAN type and topology?
