QoS Service-Policy Error
Mavrick25
Hello Everyone,
I have a 7600 Cisco Router and I'm having problems appling this config:
service-policy output (Policy-Map_name)
bandwidth percent command is not supported in output direction for this interface
Configuration failed on:
GigabitEthernet1/16
why doesn't it work?
Giuseppe Larosa
Hello Paolo,
I hope you are well
QoS capabilities in a C7600 are linecard dependent, the use of a QoS scheduler with priority or bandwidth is not allowed on standard ethernet linecards but it can be supported for example on SIP with SPA or ES 20 linecards that are WAN oriented interfaces
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/qos.html
Hope to help
Giuseppe
Hello and Thank you as always..
Hope your doing well...
So, It seems like you can only apply it on SIP line cards?
This sucks..
I guess that explains why NBAR doesn't work either..
ufff....
