qos setting
leungcm
we are going to config qos for ds3 cct. the requirement is following:
min b/w: 20M for voip traffic
max b/w: 34M for voip traffic
min b/w: 10M for data traffic (e.g. ms sql data update, monitoring snmp traffic.... etc)
max b/w: 24M for data traffic
we check cisco that there is autoqos feature. how to config it.
if we go for traditional qos, what is the sample config? pls advice
best regards
6 Replies 6
balajitvk
Level 4
Level 4
For the AutoQos, pls. go thro. below mentioned link which describes the same with config samples,
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080500b8f.html#wp1057325
But it is better to go for LLQ for more granularity,
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a0080087b13.html#wp7313
assign voice traffic with Priority b/w of 34M and assign data traffic using bandwidth command of 10M and police the same with 24M for restricting the maximum bandwidth......
Rate if it does,
Rgs
Does it support 7300 and 7500 serious router?
Best regards
Auto Qos will support only on
Platforms
Software
Switches
Cisco Catalyst 2950EI
Cisco Catalyst 3550 Cisco IOS Software Release 12.1(12c)EA1
Cisco Catalyst 4500 Cisco IOS Software Release 12.1(19)E
Cisco Catalyst 6500 Cisco Catalyst Operating System 7.5.1
Routers
Cisco 2600/2600-XM Series
Cisco 3600 Series
Cisco 3700 Series
Cisco 7200 Series Cisco IOS Software Release 12.2(15)T
http://www.cisco.com/en/US/products/ps6613/products_qanda_item0900aecd8020a589.shtml
Rate if it does,
Rgs
our router is 7300 and 7500 serious, what qos config for it? please advise.
Best regards
If I config the auto qos, what one is better?
auto qos voip
or
auto qos voip trust
best regards
I config the qos as follwing:
we would like
24M for VoIP min
34M for VoIP max
class-map match-any AutoQoS-VoIP-RTP-Trust
match ip dscp ef !Interactive Voice
class-map match-any AutoQoS-VoIP-Control-Trust
match ip dscp cs3 !Telephony Signaling
match ip dscp af31 !voice signaling
policy-map AutoQoS-Policy-Trust
class AutoQoS-VoIP-RTP-Trust
priority percent 70
class AutoQoS-VoIP-Control-Trust
bandwidth percent 5
class class-default
fair-queue
interface Serial1/0
ip address 192.168.70.1 255.255.255.252
auto qos voip trust
dsu bandwidth 44210
service-policy output AutoQoS-Policy-Trust
rate-limit output access-group 130 24000000 10000000 2000 conform-action continue exceed-action drop
access-list 130 permit ip 192.168.30.0.0 0.0.0.255 192.168.101.0 0.0.0.255
anything we need to improve it? thanks
best regards
