QoS Shaping Value
de1denta
Level 3
Level 3
Hi All,
Our MPLS provider has configured the following shaper on the WAN interface on our CE router. Its a 100Mbps interface with a 10Mbps CIR. Can anyone explain why the average rate is not set to 10000000? All that I can think of is to account for overheads but I cant work out how they came to this value? The burst value makes sense as this produces a 4ms TC.
policy-map Shaper
 class class-default
 shape average 8968000 35968
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Yes, the reduction is probably to allow for L2 overhead.  As the overhead varies per packet, you could allow for worst case or average case. Their reduction looks to be for average case (usually in the range of 10 to 15%), but as such, I don't know why they chose the exact value they did.
BTW, from a QoS perspective, if your CIR is 10 Mbps, QoS would work better if you actually ran the interface at 10 Mbps.
