QOS traffic issue
Just Kennie
Please i have a production network connected to the branch through tunnel over ISP cloud. My issue is the link is 128kbps, but the users over use the link amount to around 150kbps with exchange,and netbios taking most of the BW. What I want is I want the level of priority to be as follows. Http(s),mail and may be netbios e.t.c. Please give me a typical config template.
Joseph W. Doherty
Don't know if there's "a typical config template". But using CBWFQ might match your requirements, assuming it's supported by your platform.
For an idea: (NB: syntax likely incorect)
class-map match-any HiPriority
match protocol http
class-map match-any MidPriority
match protocol exchange
class-map match-any LoPriority
match protocol netbios
match protocol ftp
policy-map SampleCBWFQ
class HiPrioity
bandwidth percent 25
class MidPrioity
bandwidth percent 5
class LoPrioity
bandwidth percent 1
interface serial 0
policy-map output SampleCBWFQ
You determine number of classes, what they comprise and their allocation of bandwidth.
