QoS with access lists not working
Hi everybody,
i have a stack of 3750 (WS-C3750G-24TS-1U with IOS 12.2(53)SE2).
This is the conf I have:
class-map match-all DC_SC-to-DC_UW
match access-group 100
class-map match-all DC_SC-to-WAN
match access-group 101
class-map match-all D2D_Backup
match access-group 102
policy-map Traffic-from-SC_DC
class DC_SC-to-DC_UW
  police 200000000 1000000 exceed-action drop
class DC_SC-to-WAN
  police 800000000 1000000 exceed-action drop
policy-map D2D_Backup_Rate
class D2D_Backup
  police 100000000 1000000 exceed-action drop
interface GigabitEthernet1/0/24
description Downling_to_Edge
switchport access vlan 2
switchport mode access
speed 1000
duplex full
service-policy input Traffic-from-SC_DC
access-list 100 permit ip 168.217.144.0 0.0.0.255 168.217.146.0 0.0.0.255
access-list 100 permit ip 10.240.3.0 0.0.0.255 10.240.128.0 0.0.0.255
access-list 100 permit ip 10.240.4.0 0.0.0.255 10.240.129.0 0.0.0.255
access-list 100 permit ip 192.168.100.0 0.0.0.255 192.168.200.0 0.0.0.255
access-list 100 permit ip 168.217.144.0 0.0.0.255 10.240.129.0 0.0.0.255
access-list 101 permit ip any any
and the service policy is not catching any traffic at all. qosing is not working.
Plus the access lists are not catching anything either.
sw#sh ip access-lists 100
Extended IP access list 100
    10 permit ip 168.217.144.0 0.0.0.255 168.217.146.0 0.0.0.255
    11 permit ip 10.240.3.0 0.0.0.255 10.240.128.0 0.0.0.255
    12 permit ip 10.240.4.0 0.0.0.255 10.240.129.0 0.0.0.255
    13 permit ip 192.168.100.0 0.0.0.255 192.168.200.0 0.0.0.255
    14 permit ip 168.217.144.0 0.0.0.255 10.240.129.0 0.0.0.255
sw#sh ip access-lists 101
Extended IP access list 101
    10 permit ip any any
I configured a span port and did packet sniffing --> i can see traffic between the subnets inside the access lists, in both direction.
Vlan 2 is the vlan i use to do eigrp with the device directly connected to port 1/0/24.
interface Vlan2
ip address 10.122.0.2 255.255.255.240
router eigrp 100
network 10.122.0.0 0.0.0.15
Any idea?
Thanks.
  Please post "Switch#show mls qos" If it's not enable , pls do "mls qos" command on global configuration mode.
HTH,
Toshi
sw#sh mls qos
QoS is enabled
QoS ip packet dscp rewrite is enabled
thanks. i tried that before posting my original thread.
   It seems you won't see the hits on ACLs applied on policy-map. You cannot use "show policy-map interface" to see the output on C3750 as well. You can check the policy working or not by using  "show mls qos interface g1/0/2 statistics | include Policer: Inprofile:"
HTH,
Toshi
Florin Barhala
Level 6
Level 6
You will not see any hits on the ACLs either QoS works or not. On the other hand try to limit/police traffic harder, instead of 800mbps limit it to 20Mbps and see it done.
If all these will fail, you have to use srr-queue configuration. I will try these days a lab config to properly test it.
