Difference Between Static Routes..
vipin kumar
Community Member
Hi All,
I am new to the cisco IOS. As all know that there are two ways to configure the static route.as
IP route 10.0.0.0 255.255.255.0 < next Hop IP Address >
and
IP route 10.0.0.0 255.255.255.0 <  Exit Interface >.
Can anyone explain the diference between thses to static routes ..
Any help willl be appreciated. Thanks in advance
   "IP route 10.0.0.0 255.255.255.0 <  Exit Interface >"  works perfectly for point-to-point interface such as serial interface.
   "IP route 10.0.0.0 255.255.255.0 < next Hop IP Address >" is recommended for multi-acess network such as Lan segment. ARP is used to solve the next-hop mac-addresss.
HTH,
Toshi
Hi ,
And is mandatory on frame-relay physical serial interface and point-to-multipoint interface because there is no such thing as proxy InARP unlike in ethernet where there is proxy ARP.
Regards.
Alain.
Florin Barhala
Level 11
Level 11
On point to point interfaces like Serials/Tunnels, there will be no difference. But on FastEthernet interfaces think how your router will do it if it's connected to a switch with 24 ports, it will send out traffic to switch's interface, then what?
So 99% fo the times use next_hop_IP instead of exit_interfaces.
