Query on 3640 Router[AMD Presidio2]
mithil_r
Hi Friends...
I am struggling with this type of ethernet interface on 3640 as I need it to support 100 Mb whereas I read somewhere on net that this type of hardware "AMD Presidio2" won't support 100 Mb. Max this type on interface would support is 10 Mb full duplex. Could someone please let me know the way out of this??? Attached below is the show version and brief description of sh controllers.
sh version :
IOS (tm) 3600 Software (C3640-JS-M), Version 12.2(7), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 15-Jan-02 02:32 by pwade
Image text-base: 0x600089A8, data-base: 0x614FE000
ROM: System Bootstrap, Version 11.1(19)AA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)3640-uptime is 1 day, 3 hours, 18 minutes System returned to ROM by power-on System image file is "flash:c3640-js-mz.122-7.bin" cisco 3640 (R4700) processor (revision 0x00) with 45056K/4096K bytes of memory.
Processor board ID 11414217
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0 Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
2 Ethernet/IEEE 802.3 interface(s)
DRAM configuration is 32 bits wide with parity disabled.125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
sh controllers :
Interface Ethernet0/0
Hardware is AMD Presidio2
ADDR: 623CBDA8, FASTSEND: 6002C580, MCI_INDEX: 0
DIST ROUTE ENABLED: 0........................
Interface Ethernet0/1
ADDR: 623CFF58, FASTSEND: 6002C580......
Thanks & Regards,
MITHIL
spremkumar
Level 9
Level 9
Hi Mithil
You are rite we too had few AMD ethernet ports which was working fine with 10Mbps Max speed.
regds
Martin Parry
Level 3
Level 3
Hi Mithil
I believe the problem is down to the fact that you only have Ethernet interfaces (10BaseT) in your router not FastEthernet interfaces (10/100).
The best way to resolve this is to install a network module with FastEthernet interfaces into the router.
These modules include
NM-1FE2W
NM-2FE2W
NM-1FE-TX
Hope this helps. If it does, would you mind rating this post?
Martin
