Question about Eigrp restribute static to two different clouds
HWangLoyalty_2
There are two different MPLS clouds at our Data Center. We set up two different Eigrp sessions on our core switch such as:
router eigrp 100====(CloudA)
redistribution static
distribute 3 out static
router eigrp 200====(CloudB)
distribute 5 out static
ip route 1.1.1.0 255.255.255.0 1.1.3.1
ip route 1.1.2.0 255.255.255.0 1.1.3.1
ip route 1.2.1.0 255.255.255.0 1.1.3.1
access-list 3 permit 1.1.1.0 0.0.0.255
access-list 3 permit 1.1.2.0 0.0.0.255
access-list 5 permit 1.2.1.0 0.0.0.255
Both 1.1.1.0 and 1.1.2.0 are redistributed to CloudA. Subnet 1.2.1.0 are redistributed to CloudB.
There is only CloudA at SiteA (3.3.3.0/24)and only CloudB at SiteB(4.4.4.0/24).How to connect them as there is not siteB subnet in the CloudA ? Could I add only
access-list in core swicth on Data Center,likt that:
access-list 5 permit 3.3.3.0 0.0.0.255
I am not sure if SiteA subnet could be redistributed to CloudB, Please advice!
Thx
milan.kulik
Level 10
Level 10
IMHO, you could configure static routes for the subnets 3.3.3.0/24 and 4.4.4.0/24 and add them to access-list 5 (access-list 3, respectively).
But a clean solution (and more flexible for possible other subnets added in the future) would be a 3.3.3.0/24 redistribution from eigrp  100 to eigrp 200 and 4.4.4.0/24 redistribution from eigrp 200 to eigrp 100.
So you could configure:
redistribute eigrp 200 route-map from-200 metric ...
redistribute eigrp 100 route-map from-100 metric ...
route-map from-200 permit 10
match ip address prefix-list siteB
route-map from-100 permit 10
match ip address prefix-list siteA
ip prefix-list siteB seq 5 permit 4.4.4.0/24
ip prefix-list siteA seq 5 permit 3.3.3.0/24
The command syntax might be slight different, but I hope the idea is clear.
HTH,
Milan
