Question about power down
wshngai
I have a RVS4000 and a WRT54GL router at home... I am planning to power down my home completely for several hours, my question is will I have to re-setup everything or will it retain the settings within the router?
Thanks in advance for your response!!
-WN
6 Replies 6
Leo Laohoo
I'm no expert on these two models but did you save your configuration?
I did save the settings, but the problem is that I won't be at that location for the power down and I don't want to fly there just for that.  My parents will just be unplugging and plug it back in, they have no clue how to set it up.  So I am wondering how long can they have the routers unplugged without having to re-setup everything or reload the setting files.
Thanks!
-WN
hi,
i also have a WRT54G at home and have been using it for a couple of years now. you could simply just power it on again and would work just fine. you may wana do a backup its config just in case something might go wrong. just go to Administration > Config Management > Backup. i can't say much for RVS400 though.
Thank you for your reply!!  I have asked another person and he said the same thing.  Now I am wondering for the RVS4000.
Thanks!
-WN
Take a picture of the setup before the power down.
WN
I do not have experience with this specific equipment. But with ths type of router I would expect it to maintain its stored config for at least several months of power down. If your outage is going to be measured in hours I would not expect any problem. But as others have mentioned it would be helpful to make sure that you have a copy of the config or setup stored somewhere other than on the router.
Rick
Rick
