Policy Based Routing for SMTP traffic via Second ISP
AdmShatan
Hi All,
     I've been lurking these boards for a while grabbing tips to use while I work; now I need to ask for some help.  I have been trying to set up thr router to send SMTP traffic over a specific interface, NAT'd appropriately, and have all other traffic sent over a different interface.  The interfaces were intially set up as a failover from one to another using ip sla's.
What  have right now is a cable isp (ISP1), and a T1 (ISP2).  Currently, when we turn up fe04, all traffic goes out the interface, and when we turn it down, all traffic goes out the T1
Here's the relevant config(IP addresses removed, hopefully):
interface FastEthernet4
description $FW_OUTSIDE$$ETH-WAN$
ip address 1.1.1.1 255.255.255.252
ip nat outside
ip virtual-reassembly
zone-member security out-zone
shutdown
duplex auto
speed auto
crypto map VPN
interface Vlan1
description $FW_INSIDE$
ip address 192.168.x.x 255.255.255.0
ip nat inside
zone-member security in-zone
interface Vlan10
ip address 2.2.2.2 255.255.255.248
ip nat outside
crypto map VPN
ip nat inside source static tcp 192.168.x.y 80 interface Vlan10 80
ip nat inside source static tcp 192.168.x.y 443 interface Vlan10 443
ip nat inside source static tcp 192.168.x.y 1723 interface Vlan10 1723
ip nat inside source static tcp 192.168.x.y 4125 interface Vlan10 4125
ip nat inside source static tcp 192.168.x.y 25 interface Vlan10 25
ip nat inside source route-map ISP-primary interface FastEthernet4 overload
ip nat inside source route-map ISP-secondary interface Vlan10 overload
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 1.1.1.2 10 track 2
ip route 0.0.0.0 0.0.0.0 2.2.2.3 track 4
ip sla 12
icmp-echo 1.1.1.2 source-interface FastEthernet4
timeout 500
threshold 500
frequency 1
ip sla schedule 12 life forever start-time now
ip sla 22
icmp-echo 2.2.2.3 source-interface Vlan10
timeout 500
threshold 500
frequency 1
ip sla schedule 22 life forever start-time now
access-list 1 permit 192.168.x.y 0.0.0.255
access-list 100 deny   tcp host 192.168.x.y eq smtp any
access-list 100 deny   tcp host 192.168.x.y any eq smtp
access-list 100 permit ip 192.168.x.y 0.0.0.255 any
route-map ISP-primary permit 10
match ip address 100
match interface FastEthernet4
route-map ISP-secondary permit 10
match ip address 101
match interface Vlan10
route-map SDM_RMAP_1 permit 1
match ip address 107
From My understanding, This should allow me to have traffic travel over the cable link, and have SMTP travel over the T1.  That's not the case though?
Would something like this work:
access-list 151 permit   tcp host 192.168.x.y eq smtp any
access-list 151 permit   tcp host 192.168.x.y any eq smtp
route-map smtprule permit 20
match ip address 151
match interface vlan10
interface vlan10
     ip policy smtprule
fgasimzade
Level 4
Level 4
I have little experience with route maps but to route trafic from specific interface you need to add a command
set interface vlan10
not match interface vlan10 - this command matches trafic on interface 10, not directing trafic to exit through this interface
fgasimzade,
     I appreciate the reply.  I will attempt this today, and will reply back with the outcome.
Unfortunately, that didn't seem to take.  I also applied the ip policy to the internal interface, which seemed to take down just the server. Here's what I put into the config:
access-list 151 permit ip host 192.168.x.y any
route-map smtprul permit 5                 *****Yes, I mispelled it, but kept it consistent through the config.
set interface Vlan10
interface Vlan10
ip nat outside
ip policy route-map smtprul
crypto map VPN
ip nat inside source route-map smtprul interface Vlan10 overload
When I placed this into the config, all other machines and servers correctly exited the fe4 cable interface.  Ther server dropped off though, and wouldn't route out.   I believe this may be a NAT issue?  Or am I missing something more basic?
