question about the result of command "Show ip nbar protocol-discovery"
ciscoroyzhang
      hi here,  when issue show ip nbar protocol-discovery in the router, i get following result, can I assume that on the Gi0/0 ingress traffic comsumes 7899000 for the last 30 sec. if this is correct, why in same time when I try sh int gi0/0, it indecates the bandwidth utilzation is 3927000 bits/sec. why there is the diffiderence and which one show the real bandwidth utilzation during that 30 seconds?    cheers Roy
GigabitEthernet0/0
                            Input                    Output
   Protocol                 30sec Bit Rate (bps)     30sec Bit Rate (bps)
   exchange                 1336000                  247000
   http                          1454000                  100000
   secure-http              240000                   36000
   ldap                          158000                   76000
   winmx                       66000                    0
   telnet                       10000                    1000
   netbios                      6000                     3000
   dns                           5000                     2000
   snmp                        2000                     3000
   skinny                      2000                     1000
   icmp                        2000                     1000
   unknown                  4618000                  288000
   Total                        7899000                  758000
_____________________________________________________________________________________
sh int gi0/0
30 second input rate 3927000 bits/sec, 587 packets/sec
30 second output rate 642000 bits/sec, 486 packets/sec
Giuseppe Larosa
Hello Roy,
have you configured load-interval 30 under gi0/0?
the default timer for load interval is 5 minutes
with a traffic of 7 Mbps it takes up to 20 minutes for the rate to reach the 7 Mbps value with the default 5 minutes timer because it is an exponentially weighted average.
Hope to help
Giuseppe
