how to block url in Router
rajib_das
I am usning IOS Version 12.3(25) in my router . how to block  url  say for example  "http://www.xyz.com/example/xyz.html"   not the main url
http://www.xyz.com/ .
Pls help.
Thank in advance.
Raj
sean_evershed
Level 7
Level 7
One solution is to use NBAR: https://supportforums.cisco.com/message/3604592#3604592
Don't forget to rate posts that are helpful.
That can be done with NBAR:
http://www.cisco.com/en/US/partner/docs/ios/ios_xe/qos/configuration/guide/clsfy_traffic_nbar_xe.html#wp1166714
But i'm not sure if it is already in your IOS which is really old. I think it was introduced in 12.3T, so perhaps you need to upgrade your IOS.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
