Question about Wireless configuration on 877W
keeleym
Level 5
Level 5
Hi All
I am trying to configure my 877W router (Adv IP Services) to allow wireless clients connect to the internet.
At present if I connect my laptop to the router with a CAT5 cable I can access the internet. My router is supplying my laptop with an IP address via DHCP.
I have downloaded the following document as reference
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_example09186a00808acf2f.shtml
When I get to the part about configuring the VLAN (under the section "Configure Open Authentication with WEP Encryption") it shows to choose VLAN1, check the "Native VLAN" check box and enter the IP information for the VLAN.
I currently have VLAN1 configured with the IP address 192.168.1.254/24, so I entered this information but the router will not take it and prompts to pick a new IP address.
Currently as I said I have VLAN1 configured with 192.168.1.245/24 and my router is supplying IP addresses from this range via DHCP. I just want to enable wireless and extend this range to wireless clients.
Can someone explain what I need to do get get this to happen.
Best Regards & TIA,
Michael
7 Replies 7
paolo bevilacqua
Hi, you should have that:
bridge irb
bridge 1 route ip
int vlan1
no ip address
bridge-group 1
int bvi1
ip address ... <--put router ip address here
ip nat inside
int dot11radio0
bridhe-group 1
Try without security first, then configure what you like under dot11radio0
Hope this helps, please rate this post if it does!
Hi There
Thanks for the response. I have managed to get the wireless interface up and I can connect my laptop and get an IP address. However I can not access the Internet from my laptop.
My current configuration is attached
If anybody can give me any more pointers, it would be much appreciated.
Best Regards,
Michael
Sorry, here is the configuration .
Hi Michael,
I don't see anything wrong with your config, can you please post the output from typing
show ip nat trans
show ip dhcp bind
Tell us what IP address your laptop has.
Also, are you able to connect to the internet via the wired interface on this router?
__
Edison.
Hi Edison
Thanks for the response and sorry for the delay in responding. I think that we are in different time zones. I'm located in Dublin, Ireland.
Anyway I connected my 877W back onto the ADSL connection this morning and initially I still could not connect.
I ran the two commands you suggested and they came back blank. I checked my laptop and it had an IP address 192.168.1.10/24 with a default gateway of 192.168.1.254 as expected. I did notice that this was the same IP address as I had when I was connected to the old Netopia router supplied by my ISP.
Anyway I ran ipconfig /release and ipconfig /renew on the laptop and although I have received the same IP address again, this time the commands you listed do produce output. See below (public addresses x'ed out)
home_net#sh ip nat trans
Pro Inside global Inside local Outside local Outside global
tcp xxx.xxx.xxx.xxx:3947 192.168.1.10:3947 xxx.xxx.xxx.xxx:80 xxx.xxx.xxx.xxx:80
tcp xxx.xxx.xxx.xxx:3954 192.168.1.10:3954 xxx.xxx.xxx.xxx:80 xxx.xxx.xxx.xxx:80
tcp xxx.xxx.xxx.xxx:3955 192.168.1.10:3955 xxx.xxx.xxx.xxx:80 xxx.xxx.xxx.xxx:80
tcp xxx.xxx.xxx.xxx:3965 192.168.1.10:3965 xxx.xxx.xxx.xxx:80 xxx.xxx.xxx.xxx:80
home_net#sh ip dhcp bind
Bindings from all pools not associated with VRF:
IP address Client-ID/ Lease expiration Type
Hardware address/
User name
192.168.1.10 xxxx.18de.xxxx.45 Mar 02 2002 05:56 AM Automatic
Now I can surf the net via the 877 :) and I have managed to set up WEP for the moment, so I have the same level of security that I had with the ISP's Netopia. I am now looking at changing this to WPK.
If you do not mind, I wonder if you would take a look at my latest configuration and if you have any thoughts on increasing the security of the router, or any links to securing an home ADSL router, it would be much appreciated.
Again, Thanks a million for your support.
Best Regards,
Michael
Hi Michael,
I'm glad you are able to surf the internet via wireless :)
As for securing your router, there is a very little feature called 'AutoSecure' in IOS.
Please check it out:
http://www.cisco.com/en/US/docs/ios/12_4/secure/configuration/guide/hatosec.html
HTH,
__
Edison.
Hi Edison
Once again, thanks a million. The link was very useful.
Best Regards,
Michael
