question in multipoint interface bandwidth?
Dr.X
Level 2
Level 2
helo bro,
assume i have a serial interface with default bw = 1.5 mega
now if i used 3 subinterfaces , what is the bw of each subinterface >???? is it 1.5/3 or it is 1.5 mega for each one???
thanks \
Marwan ALshawi
Hi Ahmed
technically the interface-bandwidth is allocated to you by a service provider with 1.5
so the main interface logical pipe is 1.5
by using cisco QoS policies you can shape/police each sub interface to certain amount of bandwidth to be aligned with each remote site
for example main site 1.5
and remote site each 512
then you can shape each sub interface to use max of 512 with some burst when applicable
hope this help
if helpful Rate
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
Physical bandwidth is your 1.5 Mbps shared.  So unless you shape or police the subinterfaces, and one subinterface might have the full 1.5 Mbps or might have less than 500 Kbps (the latter depending on how fairly or not all 3 subinterfaces share the 1.5 Mbps).
If you wondering how to set the logical bandwidth, doesn't matter much unless the remotes have different bandwidth available.  Since each subinterface can utilize up to the full 1.5 Mbps, normally would suggest setting each logical bandwidth to 1.5 Mbps so if the subinterface is being monitored, you can accurately measure bandwidth usage. You would also set the main interface's bandwidth to 1.5 Mbps.
