question in plan for rescue while configuring router
Dr.X
Level 2
Level 2
hi ,
i just want to ask about replacing running configuration with  another config file
my scenciarioo is ,
sometimes i make some config to router , but sometimes i make mistake ,
my request is , if i  find any  problem occured during new config , i want to return to the old config
i have router 7206  , and before doing any thing  , i copy the running config to the flash disk ,
and then config my new configurations , now if  problem occured , i just  copy old config from flash to running config  .
but the problem is  , the running config is not erased then the config flash is put ,
accept the new config which is not in both flash and running configuration !!!!!!!!
my question is , how to make a plan rescue as if an urgent problem occured to return to the old config without rebooting the router ????
is my soultion which imply that copying old config from flash to running is suffient ??? or it have some cavets ???
best regards
John Blakley
You may want to look into archiving the config. Then when you make a change you can do a "config replace "
HTH,
John
HTH, John *** Please rate all useful posts ***
John Blakley
HTH,
John
hi , mr john
your reply is extremmely what im looking for
thanks very much , u really helped me .
regards
