Question of ASR1001X snmp trap envmon
kazz180snow
I can't set snmp-trap "snmp-server enable traps envmon" at ASR1001X(IOS-XE:15.4(3)S2)
Please teach me the other way.
when you issue the command 'setup' from the router prompt:
Router#setup
you are entering the System Configuration Dialog. One of the steps (Step 8) is to configure SNMP Network Management:
Configure SNMP Network Management? [no]: yes
The default is no. Turn it on by setting it to 'yes'.
http://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/1001-x/asr1hig/asr1pwrup.html#pgfId-1107823
