question related to line vty password
thara
I am new to IOS. Can we set type 8,9 for line vty password? because the default one is type 7.
line vty 0 4
password 7 0832494D1B1C11574B4B1801393F
login
Thank you
balaji.bandi
depends on the IOS you using, the options will  show you as below :
(config-line)#password?
0 Specifies an UNENCRYPTED password will follow
7 Specifies a HIDDEN password will follow
LINE The UNENCRYPTED (cleartext) line password
BB
you can use below for additional details about types
https://www.router-switch.com/faq/six-types-of-cisco-password.html
Good luck
KB
