Question related to NAT/TCP
jbluciani
Hello all,
I have a 'public' network connected to a 'private' one. Two routers, configured as main/backup, interconnect the private and public networks.
To allow a specific private host to go on the public network, I configured a static nat on the interconnection routers:
interface <to_private_network>
  ip nat inside
interface <to_public_network>
  ip nat outside
ip nat inside source static <private_ip> <public_ip>
I have now a weird result.
UDP-based applications (like snmp) are ok but TCP-based applications (like telnet ou https) are not.
The nat works correctly but the connection stopped after the nat.
Have you ever seen such a behaviour before?
Jean-Baptiste
mrdogantr
     Can you share your config file.
BR.
Muammer
and also your topology.
But to get nat working with a redundant setup like yours you must use stateful nat(SNAT).
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t13/feature/guide/ftsnat.html#wp1051530
Regards.
