Queues assignment on C3650 and C3850
JAN DEVOS
Allthough auto qos creates exactly the same classes and policy-maps on both platforms, I observe that other queues are used.
On C3650, the 8 Q's are well-aligned to the 8 defined classes, as per my empirically developped table below.  In fact, I marked traffic in the different DSCP values of col 2 and could find which queue those DSCPs go in, per the command : 'show platform qos queue stats '
Type traffic
PHB/CS
DSCP
Q#
Class name
Priority (voice)
CS4,CS5,EF
32,40,46
AutoQos-4.0-Output-Priority-Queue
NW control
CS2,CS3,CS6,CS7
16,24,48,56
AutoQos-4.0-Output-Control-Mgmt-Queue
Video
AF41,AF42,AF43
34,36,38
AutoQos-4.0-Output-Multimedia-Conf-Queue
Transactional
AF21,AF22,AF23
18,20,22
AutoQos-4.0-Output-Trans-Data-Queue
Bulk data
AF11,AF12,AF13
10,12,14
AutoQos-4.0-Output-Bulk-Data-Queue
Scavenger
CS1
8
AutoQos-4.0-Output-Scavenger-Queue
Signaling
AF31,AF32,AF33
26,28,30
6
AutoQos-4.0-Output-Multimedia-Strm-Queue
Best Effort
DF
class-default
On C3850 however, the Classes Scavenger and MultimediaStrm  generated by Auto Qos are assigned to respectively queue Q4 and Q1, whereas Q5 and 6 are left empty.
Apart from the fact of discrepancy between both switchtypes, I'm afraid Scavenger will compete with Bulk and Strmg with Mgmt within their respective shared queue.  Despite the fact that all traffic types are policed with a 'remaining %' in the policy map.  To my knowledge, scheduling for a remaining % can only be done between queues, not inside the same queue.
Your help is highly appreciated.  Both switch types run IOS XE version 03.06.04.E
Joseph W. Doherty
Duplicate post - see https://supportforums.cisco.com/discussion/12948846/queues-assignment-c3650-and-c3850
