EIGRP Gateway Fail Over
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-29-2016 08:10 AM - edited 03-05-2019 07:00 AM
hi,
I have Eigrp running between two sites and both sites have ISP links how can i Configure ISP Fail over with Eigrp.
- Labels:
Routing Protocols
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-29-2016 08:28 AM
Hi you can have multiple exit points with eigrp as it supports equal cost and unequal cost load balancing but if you only want 1 ISP link active at a time use hsrp between the routers
is this just a lab as you would usually have BGP on your wan with eigrp redistributed into it
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/software/release/12-2_52_se/configuration/guide/3560scg/swhsrp.html
