quick qos question
pamirian76
policy-map QOS
class SIP
    priority percent 25
class class-default
    fair-queue
policy-map 3M_Shaping
class class-default
    shape average 3000000
  service-policy QOS
interface FastEthernet0/0
description *** INTERNET ***
bandwidth 20000
so this is a 20mb internet line.
I just want to make sure I understand the QOS part.
25% of the 20000 is reserved for SIP?
which means what that if there is no sip that 25% is still reserved and can not be used?
what is the shape average 3000000 doing exactly?
thanks.
12 Replies 12
joshuacmoore
The shape average command is shaping all unclassified traffic to 2.8 meg. The priority command may or may not be a strict queue. I do believe that it reserves and limits throughout for class SIP for 25% of the interface bandwidth. What is your IOS version and what platform is this on?
router:  2811
ios: 124-24.T8
so from what I understand,
it reserves 25% for SIP, remaining goes to anything else up to 2.8meg due to the shaping of 3000000.
now this 25% is this always reserved and can not be used by anything else even if SIP is not using the 25% at a given time?
thanks.
btw I have applied to to my wan interface as outgoing. I have a 20MB download and +-5MB uplaod so I'm trying to control the upload.
I know it works because on speedtest I hit 3MB with the qos on and without I hit 5MB.
thanks.
Hello
If the policy map 3M_Shaping is applied to FastEthernet 0/0 then you will be shaping all outbound traffic to 3mb and SIP traffic will be guaranteed 25% of this bw at times of congestion.
Res
Paul
Kind Regards
Paul
joshuacmoore
Yes, it only applies at interface
congestion. It's also important to know that there is not only a 25% minimum but also a 25% maximum.
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
BTW, such QoS is not restricted to just an interface.
The implicit policer only triggers when there's congestion.  I.e. it's possible for LLQ to exceed its assigned bandwidth.
Joseph W. Doherty
Disclaimer
Posting
No.
No.
It tries to insure any traffic passing through it doesn't not exceed a 3 Mbps transmission rate, on average, over some time period.  If it does, it queues the traffic.  (NB: queues can overflow, and packets will drop.)
The time period is set (indirectly) by defining a burst size.  Your posting doesn't show an explicit setting for Bc, so it will take a default value (which varies based platform and/or IOS version - common defaults use either a Tc of 25ms or 4ms).
PS:
Although in the above, I've answered your questions, I suspect your looking for a much better understanding.  If QoS is "new" to you, it's difficult to explain how the above might work if you don't (yet) have a conceptional understanding.  Additionally, QoS, with the same configuration may behave differently on different platforms and/or IOS versions.  For example, HQF can work differently than pre-HQF QoS with the same configuration, shapers and FQ operations being a couple of the differences between the two "flavors"; both in your posting.
You also didn't post what, if any, service-policy statements are on F0/0.  I would expect something like "service-policy output 3M_Shaping", but you didn't note that.  If such is there, then one wonders why there's a bandwidth statement for 20 Mbps but shaping for 3 Mbps.  One also wonders, whether the FE is running at 10 or 100.
[edit]
BTW, from you later posting, for that platform and IOS version, you're running HQF QoS.
joshuacmoore
Can you please elaborate? It is my understanding that at the parent rate congestion (shape average 300000) the priority policer will kick in to reserve a minimum and maximum of 25% of the interface bandwidth.
Is this not the case?
Are you asking that question of me? I think you might be, but you attached response to OP item(?).
Yes, sorry.
Disclaimer
Posting
As the class is defined as priority with 25%, when the parent (in this case another policy's [3 Mbps] shaper) queues packets, any packets in the LLQ will be dequeued first.  Any packets being queued in the LLQ class will be policed at 25% of the controlling bandwidth, if under a 3 Mbps shaper, this would be at 750 Kbps.  (NB: Bc, Tc and Be values, unknown.)
When it comes to "reserved", LLQ doesn't actually reserve bandwidth such that other classes are unable to use its unused bandwidth.  Again, what's guaranteed is LLQ being dequeued first.
As the LLQ's implicit policer only triggers against packets to be queued in the LLQ, it's possible LLQ traffic could actually utilize, in this example, up to 3 Mbps.  I.e. as long as the LLQ class packets aren't being queued, the implicit policer doesn't police the LLQ class traffic.
(NB: note the above applies to most ISRs, unknown if true with every platform and IOS version.)
A few things:
1. Are you suggesting that the 25% is derived from the parent shaping rate? If so why/how? I was under the impression this was always from the interface bandwidth (either default bandwidth or by the bandwidth command)
2. You keep saying "as long as it isn't being queued". Queuing would not occur unless there is contention. How is this different than the logic that the policer does not go into affect until there is contention?
Disclaimer
Posting
Yes (at least with HQF QoS).  As to how/why, those are questions only Cisco could answer.
The reason I emphasis until queued, is because the policy-map queues are not always the only queues.  For example, if the policy was applied to an interface, congestion will first queue to the hardware's tx-ring, and the policy map's LLQ implicit policer wouldn't "see" this as congestion.
As to shapers, it's my belief, on some platforms and IOS versions, the parent shaper seems to have some of its own queue that "overflow" into the child policy's queues.
So, the implicit LLQ policer only appears to apply to packets actually being queued into the LLQ.  Whereas an explicit policer would apply to all packets that match the class-map.
