quick question - router sync reporting
KSVY_KSVY_2
a quick question, is there such a thing as router synchronous report?
thank you,
Kevin
Peter Paluch
Kevin,
Can you provide more context, i.e. where this term appeared? It does not resemble anything I know but perhaps knowing more about the context in which the term "synchronous router update" was used could be helpful.
Best regards,
Peter
