Cisco 2851 ISR Not Recognizing 2-Port FE HWIC
Jay Matrona
Hi All,
I received a new HWIC and installed it.  Unfortunately it is not recognized by the router.
This is the error message in Syslog:
*Sep 17 21:07:02.175: %GT96K_FEWAN-1-UNKNOWN_WIC: slot 0, wic card has an unknown id 53B
Here is the ‘sh ver’ command.  I upgraded the IOS version thinking that could be the issue but it still does not work:
edge.bvzn.local#sh ver
Cisco IOS Software, 2800 Software (C2800NM-IPBASEK9-M), Version 12.4(22)YB6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 02-Jun-10 21:53 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
edge.bvzn.local uptime is 3 minutes
System image file is "flash:c2800nm-ipbasek9-mz.124-22.YB6.bin"
Cisco 2851 (revision 53.50) with 249856K/12288K bytes of memory.
Processor board ID
2 Gigabit Ethernet interfaces
3 Serial interfaces
4 Channelized/Clear T1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
Thanks!
Jon Marshall
Jay
You need a minimum of 12.4(15)T and you are running 12.4(22) but not the T train. So you need to upgrade. See table 1A in this link for details -
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd80581fe6_ps5855_Products_Data_Sheet.html
Jon
Thanks Jon.  Installed 12.4.24T4(ED) and it worked.
Jay
No problem, glad to have helped.
Jon
