"channel-group 0 unframed" unsupport !
syjeon
We procurred new cisco router with module 'VWIC2-2MFT-T1/E1'. Btw, we've found one command does not support like following.
XXX003(config)#controller E1 0/2/1
XXX003(config-controller)#channel-group 0 unframed
XXX003(config-controller)#channel-group 0 ?
  timeslots  List of timeslots in the channel group
reconized there is no such of 'unframed' command under controller E1.
but, Old router can assign this configuration without any issue. Old router is having module 'VWIC-2MFT-G703'
Can anyone explain what is the alternative command? which new command can be in instead?
Thanks you.
lin binbin
hi syjeon
     It seems like your sofrware on your new router maynot support this command. I suggest you to upgrade your router with the same software on your old one . Hope this can help you.
     ps, i don't know any other alternative command,sorry for that~
paolo bevilacqua
Already replied at
https://supportforums.cisco.com/message/3810939
Please avoid posting duplicates.
Hi Paolo,
You didn't reply my final queiry. I've proposed sample configuration but coudn't find your reply. but still doubt.
can you check the pre-post article and see my query?
