"ip nbar port-map" on a Cisco 1841
whiteford
Hi, I am using Netflow with my Cisco 1841 with DSL card. The 1841 is in VPN mode and I notice that we use Citrox on port 2598. Neflow sees Citric as TCP 1494 and UDP 1604, do I need to add ip nbar port-map citrix tcp 2598 to my config?
The reason I ask is I want to use QoS on the dailer card to prioritise citrix traffic. That would be my next question on how to do that.
owillins
Level 6
Level 6
Better you use this ip nbar custom citrix_cgp tcp 2598
class-map match-any citrix
match protocol citrix
Match protocol citrix_cgp
The "ip nbar custom..." command allows port range assignment.
Thanks, how do I add it to my outbound dialer interface which is the VPN tunnel?
