"Opening" Up ports 443 and 80
Eddie.brown1986
Hello Folks,
I have a webserver hosting remote desktop on my LAN. I am in need of allowing inbound traffic to be able to access my web server.
I have already put into place a few access lists in preparation to allow the traffic on the interface. I am just worried that when I apply these access lists to the interface it is going to break my configuration. I only have remote access to this device because well it is 10 000kms away.
here is the relevant router config:
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description External Interface
ip address 81.x.x.x 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description Internal Interface
no ip address
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1.20
description Vlan20 Trunk
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.30
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.0
interface GigabitEthernet0/1.40
encapsulation dot1Q 40
ip address 10.10.10.1 255.255.255.128
interface GigabitEthernet0/1.99
description Vlan99 Trunk
encapsulation dot1Q 99
ip address 192.168.99.1 255.255.255.0
interface FastEthernet0/0/0
no ip address
interface FastEthernet0/0/1
no ip address
interface FastEthernet0/0/2
no ip address
interface FastEthernet0/0/3
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool GMRA 81.85.23.210 81.x.x.x prefix-length 30
ip nat source static tcp 192.168.20.37 80 81.x.x.x 80 extendable
ip nat source static tcp 192.168.20.37 443 81.x.x.x 443 extendable
ip nat source static udp 192.168.20.37 3389 81.x.x.x 3389 extendable
ip nat inside source list 7 pool GMRA overload
ip nat inside source static tcp 192.168.20.37 3389 81.x.x.x 3389 extendable
ip route 0.0.0.0 0.0.0.0 81.x.x.x
access-list 7 permit 192.168.20.0 0.0.0.255
access-list 101 permit tcp any any eq 443
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any any eq 3389
access-list 101 deny any any
If I apply Access-list 101 to my outside interface will I have an issue with internet access and will this allow those ports to have incoming connections?
If not can someone help me out
Thanks in advanced,
Eddie
cadet alain
if you apply this ACL to your outbound interface in the inbound direction  then it will only permit traffic from outside destined to ports 80,3389 and 443 but your reply traffic in response to traffic originated in your LAN will get dropped.
You can apply the ACL though but at the same time use CBAC:
config t
ip inspect name MY_INSPECTION tcp router-traffic
ip inspect name MY_INSPECTION udp router-traffic
ip inspect name MY_INSPECTION icmp router-traffic
int g0/0
ip inspect MY_INSPECTION out
ip access-group 101 in
Alain
7 Replies 7
cadet alain
config t
int g0/0
Alain
Thanks Cadet,
I will do some reading CBAC and update this forum accordingly.
Eddie
Hello Cadet,
I have configured CBAC and applied the access-list to my outside interface pointing inbound. Yet I am still unable to gain access to my webserver. I went to grc.com and used "sheild's up!" to test my opened ports and it is reporting that those two ports are still closed.
From what I have been reading CBAC and the ACL shouldn't be nessecary, only a Static NAT pointing to the inside should be needed.
I'm at a loss for what needs to be done, if sheilds up would have reported those ports opened then I would have went back to the application side and quadruple checked all of my server settings.
Do you have any other idea's?
Eddie
Hi Eddie,
of course these are not needed for the port forwarding to work but if you apply the ACL inbound on your WAN interface as is then you'll lose connectivity from inside to outside because ACLs are stateless and if you do not permit the return traffic then it will be dropped inbound on the WAN interface and that's why I told you to use the IOS stateful firewall feature.
I think you should get rid of the security and try to connect to the server from outside with only NAT enabled.
Can you tell us if it is working  this way ?
Alain
Hello Cadet,
Before you suggested to use the CBAC and apply my ACL to the outbound interface I did not have anything but the static NAT entry. Everything that I have been reading has suggested that just the static NAT should be fine. However Sheilds Up! port scanner has replied with port 443 and 80 closed.
What if I apply an ACL to both the inbound and outbound interface opening up access to these ports. Allowing the return traffic to traverse in inside network?
This has been resolved, I was using the extendable command, and decided to not and BAM! I am able to access the webpage now.
Hi Eddie,
Thanks for letting us know that your problem is resolved and what was causing it.
Alain
