RDP QoS on a Cisco 881W
Johan Olsson
I need some guidelines how to setup QoS on a 881W router.
I have a small office with a 4Mbit internet connection. My users are today working on a remote terminal server and they often experience small interruptions which make their remote sessions hanging and they are all complaining about the performance.
I’ve monitored of the connection and it looks to be stable. The problem is when users are downloading data or synchronizing their computers to other remote services.
How do I setup QoS in the best way so that RDP (both port 3389 and 443) traffic allways get priority over other traffic?
Thanks for any suggenstions
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
"Best way"?
Internet connection, for both sides, support "normal" Internet access?  If so, "best way" would be stop doing that.
If Internet connection is devoted to just your business traffic between two of your sites, you shape egress traffic for bottleneck bandwidth (usually the lower guaranteed bandwidth for either site) and use QoS to prioritize your traffic.  In your case, class-default FQ might work, if not, if your IOS version supports HQF, multiple classes using FQ, with extra bandwidth defined for your RDP should do.  (The latter might be the "best way".)
