Showing results forĀ
Search instead forĀ
Did you mean:Ā
"show process cpu monitor" Stops Unexpectedly
William-C
Hello Everyone. I'm looking to utilize the "show processes cpu monitor" task to view and validate cpu services and usages on a Cisco 4461 Router with IOS version 17.06.05.
I go to use the command and will show the cpu utilization for the first 5 seconds. It's supposed to continue to monitor and refresh every 5 seconds, or any interval time you set above 5 seconds. Unfortunately, it stops monitoring after the interval time is reached and puts me back into privileged exec. I have another router with the same model and IOS build but does not suffer the same unexpected stop to the monitor process and continues as it should. CPU and Memory utilization is not maxed out, so it shouldn't be a problem with not enough resources.
Does anyone have any ideas as to why this Monitor process stops?
CPU utilization for five seconds: 9%/4%; one minute: 9%; five minutes: 10%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
579 94264097 305437800 308 1.43% 1.34% 1.32% 0
137 78968723 1645405478 47 0.79% 0.85% 0.90% 0
887 42882964 32157081 1333 0.39% 0.48% 0.47% 0
92 9924003 79905851 124 0.31% 0.15% 0.15% 0
817 12030063 404810931 29 0.23% 0.18% 0.18% 0
329 9111513 126470390 72 0.23% 0.13% 0.13% 0
833 25413033 229398031 110 0.15% 0.18% 0.21% 0
799 2347958 88484687 26 0.15% 0.04% 0.02% 0
800 10497061 280445141 37 0.15% 0.13% 0.14% 0
836 31530180 230137752 137 0.15% 0.15% 0.19% 0
835 72834 1927451 37 0.07% 0.00% 0.00% 0
821 6100752 47737571 127 0.07% 0.08% 0.07% 0
826 1558378 203846799 7 0.07% 0.02% 0.00% 0
586 1287310 5480039 234 0.07% 0.01% 0.00% 0
15 2049793 21691134 94 0.07% 0.02% 0.01% 0
848 985 6395 154 0.07% 0.03% 0.00% 867
875 3915930 327859710 11 0.07% 0.05% 0.06% 0
583 1291720 78950997 16 0.07% 0.02% 0.01% 0
889 1837969 130780709 14 0.07% 0.02% 0.00% 0
141 4062137 400903979 10 0.07% 0.06% 0.07% 0
End = e Freeze = f
Enter Command:
Router-01#
marce1000
    - Use latest advisory release on the device  https://software.cisco.com/download/home/286320564/type/282046477/release/Cupertino-17.9.4a
                           and check again ,
 M.
