"xmodem:: permission denied" when upgrading IOS through ROMMON
arifdatau
I need help, I was trying to upgrade my router 2691 with c2691-entservicesk9-mz.124-13b.bin from the old IOS c2691-adventerprisek9-mz.124-25b.bin and maybe the file got corrupted so no matter I tried to solved it still did not work. I guess I just got stuck and I have no idea how to fix it. Please take a moment look at this and perhaps you could tell me what is wrong with this.  I thanks in advance for this.
Readonly ROMMON initialized
rommon 1 > dir flash:
program load complete, entry point: 0x80008000, size: 0xca20
Directory of flash:
2      34103360  -rw-     c2691-entservicesk9-mz.124-13b.bin
rommon 2 > xmodem c2691-entservicesk9-mz.124-13b.bin
Do not start the sending program yet...
         File size           Checksum   File name
        -1 bytes (0xffffffff) 0x0001    vicesk9-mz.124-13b.bin (deleted)
WARNING: All existing data in flash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n  [n]:  y
Ready to receive file c2691-entservicesk9-mz.124-13b.bin ...
Timeout waiting for data - aborting download…
rommon 3 > boot flash:c2691-entservicesk9-mz.124-13b.bin
loadprog: error - on read during ELF program load
requested 34319676 (0x20bad3c) bytes, got 34075156 (0x207f214)
boot: cannot load "flash:c2691-entservicesk9-mz.124-13b.bin"
rommon 4 > i
System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2002 by cisco Systems, Inc.
c2691 processor with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
boot: cannot load "flash:"
rommon 4 > meminfo
Current Memory configuration is:
Dimm0: Size = 128 MB : Start Addr = 0x00000000
-----Bank 0 128 MB
-----Bank 1   0 MB
Dimm1: Size = 128 MB : Start Addr = 0x08000000
-----Bank 0 128 MB
-----Bank 1   0 MB
Main memory size: 256 MB in 64 bit mode.
Available main memory starts at 0xa000e000, size 262088KB
IO (packet) memory size: 0 percent of main memory.
NVRAM size: 32KB
I have tried everything for this but with no luck at all.
sakella
Looks like the image is deleted status. Here are few things u can try
  • If the router has two built-in Ethernet or fast Ethernet interfaces, always use the first interface (usually 0/0). You must use the built-in interface. For example, if a Cisco 1700 series router has a WIC-1ENET card installed, the tftpdnld ROMmon command does not work with that card.
  • All variable commands must be upper case. The variable itself is case sensitive as in the case of a filename, as shown in the following example:
  • rommon11>TFTP_FILE=c2600-i-mz.120-7.T.bin
  • TFTP_FILE= must be upper case and c2600-i-mz.120-7.T.bin is case sensitive.
  • The DEFAULT_GATEWAY= address should not be the same address as the IP_ADDRESS= variable. This causes the process to fail. Set the DEFAULT_GATEWAY= variable to the address of the TFTP server.
The following example shows how to perform a tftpdnld ROMmon command recovery procedure with a TFTP server at the 10.1.1.2 address, a 255.255.255.0 subnet mask, and a filename of c2600-is-mz.120-7.T.bin.:
rommon 16 > IP_ADDRESS=10.1.1.1
!--- This is the temporary IP address assigned to the router.
rommon 17 > IP_SUBNET_MASK=255.255.255.0
!--- Same as on the TFTP server.
rommon 18 > DEFAULT_GATEWAY=10.1.1.2
!--- Use the IP address of the TFTP server.
rommon 19 > TFTP_SERVER=10.1.1.2
!--- TFTP server's IP address.
rommon 20 > TFTP_FILE=c2600-is-mz.120-7.T.bin
!--- Exact name is case sensitive.
rommon 21 > TFTP_CHECKSUM=0
!--- This prevents checksum errors with earlier 2600 boot ROMs.
rommon 22 > tftpdnld
!--- This command must be lower case.
IP_ADDRESS: 10.1.1.1
           IP_SUBNET_MASK: 255.255.255.0
           DEFAULT_GATEWAY: 10.1.1.2
           TFTP_SERVER: 10.1.1.2
           TFTP_FILE: c2600-is-mz.120-7.T.bin
     Invoke this command for disaster recovery only.
     WARNING: all existing data in all partitions on flash will be lost!
     Do you wish to continue? y/n:  [n]:  y
     Receiving c2600-is-mz.120-7.T.bin from 10.1.1.2 !!!!!.!!!!!!!!!!!!!!!!!!!.!!
     File reception completed.
     Copying file c2600-is-mz.120-7.T to flash.
     Erasing flash at 0x607c0000
     program flash location 0x60440000
     rommon 22 >reset
For additional information on the tftpdnld ROMmon command recovery procedure, refer to How to Download a Software Image to a Cisco 2600 via TFTP Using the tftpdnld ROMmon Command.
Here is url
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
