Now I can't get my 877 W wireless to bridge to the lan and adsl HELP!!
Infiltratr
Agh - now that I am having problems with the 877W.  I have decided to configure it so I can use the wireless to connect and get an ip address from
my dhcp server that is on the LAN (a windows server box) and it's not working at all.
Can anyone see what i've messed up here??
Current configuration : 6631 bytes
version 12.4
no service pad
service password-encryption
service internal
hostname hostname
boot-start-marker
boot-end-marker
logging message-counter syslog
logging queue-limit 1000
logging buffered 100000
logging reload alerts
logging rate-limit console 20
enable secret 5 nopienope
no aaa new-model
clock timezone AEST 10
clock summer-time AEDST recurring last Sun Oct 0:01 last Sun Mar 0:01
crypto pki trustpoint TP-self-signed-1111
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-111
revocation-check none
rsakeypair TP-self-signed-111
crypto pki certificate chain TP-self-signed-111
certificate self-signed 01
blah blah blah
quit
dot11 syslog
dot11 ssid Wireless.net
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 nopienope
ip source-route
ip cef
ip name-server 203.12.160.35
ip name-server 203.12.160.36
ip inspect name myfw cuseeme timeout 3600
ip inspect name myfw ftp timeout 3600
ip inspect name myfw rcmd timeout 3600
ip inspect name myfw realaudio timeout 3600
ip inspect name myfw smtp timeout 3600
ip inspect name myfw tftp timeout 30
ip inspect name myfw udp timeout 15
ip inspect name myfw tcp timeout 3600
ip inspect name myfw h323 timeout 3600
no ipv6 cef
username admin privilege 15 password 7 nopienope
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5snap
pppoe-client dial-pool-number 1
dsl noise-margin 3
dsl bitswap both
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption mode ciphers tkip
ssid wireless.net
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0
36.0 48.0 54.0
channel least-congested 2412 2442 2462
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip virtual-reassembly
bridge-group 1
interface Dialer0
no ip address
interface Dialer1
ip address negotiated
ip access-group 111 in
ip mtu 1492
ip nat outside
ip inspect myfw out
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
ppp authentication chap callin
ppp chap hostname
ppp chap password 7 nopienope
ppp pap sent-username password 7 nopienope
ppp ipcp route default
interface BVI1
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list 102 interface Dialer1 overload
ip nat inside source static tcp 192.168.1.201 25 interface Dialer1 25
ip nat inside source static tcp 192.168.1.201 80 interface Dialer1 80
ip nat inside source static tcp 192.168.1.201 53 interface Dialer1 53
ip nat inside source static tcp 192.168.1.201 3389 interface Dialer1 3389
ip nat inside source static tcp 192.168.1.201 58249 interface Dialer1
58249
ip nat inside source static udp 192.168.1.201 53 interface Dialer1 53
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list 111 permit tcp any any eq smtp
access-list 111 permit tcp any any eq www
access-list 111 permit tcp any any eq domain
access-list 111 permit tcp any any eq 3389
access-list 111 permit tcp any any eq 58249
access-list 111 permit udp any any eq domain
access-list 111 permit udp any any eq 25
access-list 111 permit udp any any eq 80
access-list 111 permit icmp any any administratively-prohibited
access-list 111 permit icmp any any echo
access-list 111 permit icmp any any echo-reply
access-list 111 permit icmp any any packet-too-big
access-list 111 permit icmp any any time-exceeded
access-list 111 permit icmp any any traceroute
access-list 111 permit icmp any any unreachable
access-list 111 permit udp any eq bootps any eq bootpc
access-list 111 permit udp any eq bootps any eq bootps
access-list 111 permit udp any eq domain any
access-list 111 permit esp any any
access-list 111 permit udp any any eq isakmp
access-list 111 permit udp any any eq 10000
access-list 111 permit tcp any any eq 1723
access-list 111 permit tcp any any eq 139
access-list 111 permit udp any any eq netbios-ns
access-list 111 permit udp any any eq netbios-dgm
access-list 111 permit gre any any
access-list 111 permit tcp any any eq 123
access-list 111 permit udp any any eq ntp
snmp-server community public RO 1
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
login
transport input telnet ssh
scheduler max-task-time 5000
end
Please help!!!!
sakella
Here is a sample config  bvi dsl config 1483
LAB-DSL-CIR1#sh run
Building configuration...
Current configuration : 4637 bytes
! No configuration change since last restart
version 15.0
no service pad
hostname LAB-DSL-CIR1
boot-start-marker
boot system flash c870-advipservicesk9-mz.150-1.M.bin
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$.K1L$Vb9bp9l1UugB.DNodlpfL0
aaa new-model
aaa session-id common
clock timezone MST -7
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause rootguard
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
dot11 syslog
ip source-route
no ip dhcp use vrf connected
ip dhcp pool LAB_DSL_USERS
   network 128.196.146.8 255.255.255.248
   dns-server 128.196.11.233 128.196.11.234
   domain-name telcom.arizona.edu
   default-router 128.196.146.9
   lease 0 3
ip dhcp pool LAB_DSL_VOIP
   network 172.28.8.160 255.255.255.248
   dns-server 172.28.254.40 172.28.254.41
   default-router 172.28.8.161
   domain-name voip.telcom.arizona.edu
   option 150 ip 172.28.254.51 172.28.254.53
   lease 0 3
ip dhcp pool Wireless
   network 172.30.48.232 255.255.255.248
   default-router 172.30.48.233
   option 43 hex f104.ac10.fdaa
   lease 0 9
ip cef
no ip domain lookup
ip domain name telcom.arizona.edu
ip name-server 128.196.11.233
ip name-server 128.196.11.234
ip multicast-routing
no ipv6 cef
key chain UA-Eigrp-Key
key 1
  key-string u0fa31grp
spanning-tree backbonefast
vtp domain Stinger_Lab_Testing
vtp mode transparent
username millerjw privilege 15 secret 5 $1$Rwv6$UH5jmvVX0etq3fIeuU7Cb.
username emergency privilege 7 secret 5 $1$bwVh$mYk6sINQu.6eVkIwxqHgM/
vlan 200
name LAB_DSL_TESTING_VOIP_VLAN
vlan 900
name LAB_DSL_TESTING_MGMT_VLAN
vlan 910
name LAB_DSL_TESTING_WIRELESS_VLAN
ip telnet source-interface Vlan900
ip ftp source-interface Vlan900
ip tftp source-interface Vlan900
ip ssh time-out 60
ip ssh authentication-retries 5
ip ssh source-interface Vlan900
ip ssh version 2
bridge irb
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
atm vc-per-vp 64
bridge-group 1
pvc 8/35
switchport voice vlan 200
spanning-tree portfast
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
station-role root
interface Vlan1
description Users
ip address 128.196.146.9 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip tcp adjust-mss 1452
interface Vlan200
description VOIP
ip address 172.28.8.161 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan900
description Mgmt
ip address 172.16.101.81 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan910
description Wireless
ip address 172.30.48.233 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
interface Dialer0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
interface BVI1
description Linknet for Stinger DSL lab testing
ip address 172.17.0.186 255.255.255.252
ip authentication mode eigrp 1706 md5
ip authentication key-chain eigrp 1706 UA-Eigrp-Key
router eigrp 1706
network 128.196.146.8 0.0.0.7
network 172.16.101.80 0.0.0.7
network 172.17.0.184 0.0.0.3
network 172.28.8.160 0.0.0.7
network 172.30.48.232 0.0.0.7
redistribute connected
redistribute static
passive-interface default
no passive-interface BVI1
eigrp stub connected static
no ip http server
no ip http secure-server
logging 172.16.129.12
logging 128.196.134.65
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
login authentication console
no modem enable
line aux 0
line vty 0 4
access-class 185 in
exec-timeout 30 0
transport preferred none
transport input ssh
transport output telnet ssh
LAB-DSL-CIR1#
