04-17-2009 12:58 AM - edited 03-04-2019 04:24 AM
I have a Cisco 7204VXR Router running c7200p-ipbasek9-mz.124-4.XD5.bin IOS. However, the router only uses the extended source ports (21645 to 21844) for RADIUS authentication despite using the command
"no radius-server source-ports extended"
and reloading. Is there another way to force the router to use the default RADIUS source ports(1645 and 1646)?
04-17-2009 08:06 AM
Hello Adetola,
have you tried to specify the ports in the same line where you define the radius server ip address ?
Hope to help
Giuseppe
04-17-2009 08:10 AM
Hi Giuseppe,
Thanks for your response. I've tried that before and it gives an error at the point where I typed the port number.
04-17-2009 08:29 AM
Hello Adetola,
have you tried to use
auth-port and acct-port keywords
like in
http://www.cisco.com/en/US/docs/ios/security/command/reference/sec_r1.html#wp1061040
Hope to help
Giuseppe
04-20-2009 01:09 AM
Hi Giuseppe,
Unfortunately the hardware has been shipped top site. However, I'll try the setup in GNS3 and let you know the outcome.
Thanks.
Tola
