rate-limit command not accepting on 8200L
imsharif
Recently, I am migrating from 2900 to 8200. When trying to copy rate-limit configuration, the command is rejected.
on 2900:
interface GigabitEthernet0/2
description AIRTEL_MPLS_20Mb
ip address x.x.x.x
ip flow ingress
ip flow egress
rate-limit input access-group 117 16384000 3072000 6144000 conform-action transmit exceed-action drop
rate-limit input access-group 116 4096000 768000 1536000 conform-action transmit exceed-action drop
rate-limit input access-group 114 4096000 768000 1536000 conform-action transmit exceed-action drop
rate-limit input access-group 113 1024000 384000 768000 conform-action transmit exceed-action drop
rate-limit input access-group 109 8192000 1536000 3072000 conform-action transmit exceed-action drop
rate-limit input access-group 108 8192000 1536000 3072000 conform-action transmit exceed-action drop
rate-limit input access-group 112 8192000 1536000 3072000 conform-action transmit exceed-action drop
rate-limit input access-group 107 8192000 1536000 3072000 conform-action transmit exceed-action drop
rate-limit output access-group 117 16384000 3072000 6144000 conform-action transmit exceed-action drop
rate-limit output access-group 116 4096000 768000 1536000 conform-action transmit exceed-action drop
rate-limit output access-group 114 4096000 768000 1536000 conform-action transmit exceed-action drop
rate-limit output access-group 113 1024000 384000 768000 conform-action transmit exceed-action drop
rate-limit output access-group 109 8192000 1536000 3072000 conform-action transmit exceed-action drop
rate-limit output access-group 108 8192000 1536000 3072000 conform-action transmit exceed-action drop
rate-limit output access-group 112 8192000 1536000 3072000 conform-action transmit exceed-action drop
rate-limit output access-group 107 8192000 1536000 3072000 conform-action transmit exceed-action drop
load-interval 30
duplex full
speed 100
end
On 8200L
New-Router(config-if)#rate-limit
% Unrecognized command
New-Router(config-if)#r?
I searched on cisco, but couldn't find an answer.
balaji.bandi
May be the command deprecated, look if you can do with QoS
https://www.cisco.com/c/en/us/td/docs/routers/ios/config/17-x/qos/b-quality-of-service/preface-reuse-routing.html
BB
