Cant get internet from inside of network, works directly from router
Stelios76
Hi All,
I am very new to the networking world I am wondering if I am making an easy mistake somewhere. I have a network consisting of a cisco 2921 router and 4 copper cisco switches. Into the router, I have a link to an ISP who have given me a public IP address to use on my routers internet facing interface. On the internal part of my network I have an internal link from router to one of the 4 switches, which the other three connect to via trunk links, I have used 192.168.10.0 as my network address with a /26
prefix
and have created a DHCP pool on the router's internal interface which correctly assigns IP addresses when connecting. However, no matter what, I simply cannot access the internet when plugging into one of the TAPs.
Apologies if I am doing something really basic wrong. I have applied PAT to the outside interface but when I connect to a TAP, the ethernet adapter finds the network but just says no internet. Here is the router config below with public ip addresses omitted - if i need to provide any more information which might make it easier I am more than happy to do, this is driving me mad so any assistance would be greatly appreciated. The most annoying aspect of this is when I connect straight to the ISP's router and manually assign my laptop with the same public ip address as I have assigned the router - it works wonderfully.
From a private address on the inside of the network I can ping ISP's router (next hop of my public ip) but cannot get internet.
ip dhcp excluded-address 192.168.10.1
ip dhcp pool xx
network 192.168.10.0 255.255.255.192
default-router 192.168.10.1
domain-name XX
dns-server Correct IP's4
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO2921/K9 sn FCZ2111B0ZB
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Cross site Link to x from x
ip address -ISP Assigned public ip -255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description Internal Network default gateway address
ip address 192.168.10.1 255.255.255.192
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1/0
no ip address
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
no ip address
interface GigabitEthernet0/1/3
no ip address
interface GigabitEthernet0/1/4
no ip address
interface GigabitEthernet0/1/5
no ip address
interface GigabitEthernet0/1/6
no ip address
interface GigabitEthernet0/1/7
no ip address
interface Vlan1
no ip address
interface Async0/3/0
no ip address
encapsulation slip
interface Async0/3/1
no ip address
encapsulation slip
interface Async0/3/2
no ip address
encapsulation slip
interface Async0/3/3
no ip address
encapsulation slip
interface Async0/3/4
no ip address
encapsulation slip
interface Async0/3/5
no ip address
encapsulation slip
interface Async0/3/6
no ip address
encapsulation slip
interface Async0/3/7
no ip address
encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 2 interface GigabitEthernet0/0 overload
access-list 2 permit 192.168.10.0 0.0.0.255
M02@rt37
Hello @Stelios76,
On your Router you need
default route
to the ISP IP address.
(config-t)#ip route 0.0.0.0 0.0.0.0 <ISP-IP-ADD>
Best regards
5 Replies 5
M02@rt37
Hello @Stelios76,
default route
Best regards
Hi there M02, Thank you kindly for your response, I will give this a crack tomorrow when I am back at the kit and let you know if it was successful. thanks for taking your time
You're very welcome @Stelios76
Thanks for your feedback.
Best regards
Thank you it worked!!
Great news!
You're very welcome @Stelios76.
Best regards
