Rate Limit How to?
cupidupdated
i have a cisco 3845 router where port gi 0/0 is connected to internet and gi 0/1 is to lan. WCCP is enabled on port gi 0/0 redirecting out. now if i want to rate limit a single user or a group it does not work, but if i rate limit my proxy it works - but for all users. is there any solution to it that i can rate limit any user with WCCP turned on? urgent help needed.
Note: i'm using real IP, no natting. and i'm rate limiting inbound traffic to gi 0/0.
Thanks.
smahbub
Level 6
Level 6
To configure committed access rate (CAR) and distributed CAR (DCAR) policies, use the rate-limit interface configuration command. To remove the rate limit from the configuration, use the no form of this command
For more information refer:
http://www.cisco.com/en/US/docs/ios/12_2/qos/command/reference/qrfcmd8.html
mounir.mohamed
Level 7
Level 7
HI Cupid,
Just idea and need to be tested.
I think You can use WCCP redirect-list to deny set of hosts, then rate-limit them.
Please rate helpful posts
Best Regards,
Mounir Mohamed
