Rate-limit limitations
gurupada1981
I need to put a rate-limit on my router WAN interface. I need to give a certain cap limit for respected clients.
My question is, if that cap is not being fully utilized, will the rest of  bandwidth be available to  default traffic.
and again, if capped used started utilizing more, will be they get their respected bandwidth.
Please assist.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If you cap (drop overrate) specific clients (or traffic), with a rate-limiter (or policer) it's always capped, unless you have some clever way for such traffic to bypass the rate-limiter (or policer) (e.g. such as perhaps CBWFQ classes using timed based ACLs as part of their class-map criteria.)
Whatever bandwidth, not currently being used by rate-limited (or policed) traffic would normally be available for other non-rate-limited traffic.
Hello
It looks like a MQC policy with police is a better choice for you rather than traditional rate limit. So that your application gets required bandwidth and at the same time,the excess traffic will be dropped
Harish.
Hi Harish,
Police is already configured. But when default traffic(non-policed) exceeded , policed traffic get hamper.
That's why , we are trying a committed bandwith for certain users.
Please advise.
Disclaimer
Posting
It might help if you post the relevant parts of the config.
