rate-limit on WAN interface with ACL
genseb13011
I would like to apply rate limit on my WAN interface (upstream and downstream).
I've found this configuration:
rate-limit output bandwidth normal_burst excess_burst
rate-limit input bandwidth normal_burst excess_burst
I'd like to apply these limitations to certain flow.
Can i use access-list to target this flow?
I've found this configuration (rate-limit output access-group 103 bandwidth normal_burst excess_burst) but it seems that it doesn't work
Thanks for your answer
cadet alain
you must specify the conform-action   clause.
Then show interface rate-limit to verify config.
This CAR technology is considered legacy and if your router supports you should use class-based policing instead.
Regards.
Alain.
GregCover
If all you want to do is limit "all" the traffic exiting your wan interface try using a basic shaping policy.
First, create the policy map in global config mode.
policy-map SHAPE
  class class-default
    shape average 768000    <-- or speed you desire in bits.
Then apply the command "service-policy output SHAPE" to your WAN interface config at both ends.
Hope this helps,
Greg
Also, you could get more specific with what traffic this applies to by creating specific class-maps and then referring to those class-maps in the policy map.
Greg
sanjaysk1
CAR is old way of applying policy, but it is being used frequently because of its simplicity.
Yes, access-list should be used to filter the traffic to define the desired source and destination and ensure CEF is enabled before using rate-limit.
You should follow few steps to apply rate limit on desired interface which is as below:-
+Specify what type of traffic you want to limit and the limit value.
+Verify traffic direction(In/Out)
+Apply the rate-limit command under the interface
E.g.
router(config)#access-list 101 permit tcp any any eq www
router(config)#int se0/0
router(config-if)#rate-limit output access-group 101 128000 64000 96000 conform-action transmit exceed-action drop >>>> i applied in OUT direction..
-Sanjay Singh
