Rate Limit on WAN
The_guroo_2
Level 2
Level 2
Hi guys i have a question.......what is the best way to limit your bandwisth to your customer......we are service provider and we have different customers i m pasting a config of one of them please tell me is it the right way to limit the traffic or there is better way to limit the traffic.....plus explain a lil bit how we calculate the formula (it referes to the two rate limit line) how we put numbers in that....Kindly see the attachment....thanks a million
msubtain
Those 3 values are "Configured Rate, Normal Burst and Externded Burst".
This is how cisco recommend to configure those values
normal burst = configured rate * (1 byte)/(8 bits) * 1.5 seconds
extended burst = 2 * normal burst
Load interval command controls when input/output data will be loaded for calculation, default value is 5 minutes so yours is set to 30 seconds which means you will have more current stats when you run show interface command.
Hope it helps
Muhammad
hi,
Muhammed has stated it right, but i tend to have Normal Burst = Externded Burst in order for the traffic to be firmly policed to the desired rate.
HTH, please do rate all helpful,
Mohammed Mahmoud.
