Rate limiting and Nat
ashley_dew
I have a router 3845 connected to a LAN and other routers and providing internet through a link on an ethernet interface
Gi0/0
LAN connection
GI0/1
WAN connection
fa0/0
Internet connection
NAT is used on fa0/0 for internet trafic
int gi0/0
ip nat inside
int gi0/1
ip nat inside
int fa0/0
ip nat outside
I would like to apply rate limit per user on fa0/0 as such
int fa0/0
rate-limit input rate-limit access-group 101 20000000 3750000 7500000
 conform-action transmit exceed-action drop
 rate-limit input access-group 102 10000000 1875000 3750000
 rate-limit input 8000000 1500000 3000000 conform-action transmit exceed-action drop
 ip address 200.x.x.1 255.255.255.252
 access-list 101 permit ip 192.168.1.0 255.255.255.0 any
 access-list 102 permit ip 192.168.2.0 255.255.255.0 any
Where 192.168.1.0  and 192.168.2.0 are internal LAN
Will rate limit apply before NAT and so work on the LAN ip addresses?
My second question is how the limiter applies to the ACL 101 for example. Is it each and every host/trafic that matches the ACL will be limited to the bandwidth of 20 Mbps or is it the overall trafic matching ACL is restricted to the 20 Mbps.
Thanks for your advise,
Ashley
3 Accepted Solutions
Nagendra Kumar Nainar
Hi Ashley,
Regarding NAT order of operation, below link will help you,
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080133ddd.shtml
Regarding your second question, all traffic that matches the ACL will be limited to specified rate limit value.
HTH,
Nagendra
Hi Ashley
ACL 101 matches any rource IP in the subnet 10.100.10.0/24 going to any destination IP
Which means if you have a calss match this ACL it will limit all the ip traffic coming form this subnet going anywhere including 10.100.10.1 to 10.10.10.10
However if you want to separate them for example
Traffic form host 10.100.10.1 to server 10.10.10.10 to be limited to 1000000
And traffic from 10.100.10.0/24 subnet going anywhere else including ( 10.100.10.1 going anywhere other than 10.10.10.10 ) to 2000000
Then use the bellow config example
Access-list 100 permit ip host 10.100.10.1 host 10.10.10.10
Access-list 101 permit ip 10.100.10.0 0.0.0.255 any
Class-map ACL100
Match access-group 100
Class-map ACL101
Match access-group 101
Policy-map P1
Class ACL100
Police cir 1000000
Class ACL101
Police cir 2000000
Please not that the most specific ACL/class map must be applied first top down processing
Pls rate the helpful posts
Marwan ALshawi
Hope u got the answer u want
9 Replies 9
Marwan ALshawi
Hi Ashley
i would recomnd you to use policing with policy maps and class maps rather than rate-limit as rate limit is considered now old school and the modern and scalable way is using MQC with policing
lets say you have ACL 101 and 102
create two class maps
class-map map101
match access-group 101
class-map map102
match access-group 102
then create a policy map
policy-map P1
class map101
   police cir 1000000
class map102
   police cir 1000000
then apply to the output interface in the in outbound direction
int fa0/0
service-policy outbound P!
you can confirm that if the policing ( limiting happen after that nat in terms of matching the ACL )  after you apply the policy map use the bellow command and see if there is any matching against the class map
show policy-map interface fa0/0
for more details pls refer to the bellow link
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfpoli_ps1835_TSD_Products_Configuration_Guide_Chapter.html
if helpful Rate
Hi Marwanshawi,
Thanks for your help, MQC is the best solution.
I have a query concerning the mechanism of class based
Suppose I have with an ACL 101
access-list 101 permit ip 10.100.10.0 255.255.255.0 any
So , if i have 2 connections matching the ACL, 10.100.10.1 accessing a web site and another pc 10.100.10.10 accessing another site.
Will the policing work policing each and every connection 10.100.10.1 and 10.100.10.10 for example
1000000 ?
Or is it all connections will police to 1000000, that is the sum of bandwidth utilisation of all connections matching the ACL will be 1000000 ?
Ashley
Hi Ashley,
HTH,
Nagendra
Hi Nagendra,
Thanks very much for you answer, so rate-limiting is before NAT, so no issue with using my ACL with my internal IP.
MQC works after NAT, so my ACL with my internal IP will not work. I would have got my configuration wrong.
Ashley
Hi Ashley
have you tested it or you just relying on the link ? i dont think the link is mentioning about output rate limiting and ACL matching outbound !
have a look at the bellow router processing order where i believe it is more realstic as the router dose routing lookup then translate from inside to out side then process other things
You are right, the queuing is not been after the NAT on the outbound interface where I would like to apply the QoS policy. Thanks.
Do you have an idea of my query about the bandwidth policing parameters applying to each traffic of the ACL, our the sum of  all connections in the ACL.
I have not tested it, production environment. I am just planning the configuration.
Ashley
Hi Ashley
Class-map ACL100
Class-map ACL101
Policy-map P1
Class ACL100
Police cir 1000000
Class ACL101
Police cir 2000000
Marwan ALshawi
Thanks Marwanshawi,
Excellent that is very clear.
Thanks for your help, now I understand and I can work on it.
Fantastic
