Rate limiting multiple mac addresses
slerbeton79
Hello I am trying to rate limit specific computers on my network and since all pc's are DHCP I would need to use the mac address of each specific pc.
on
access lists are:
access-list rate-limit 101 0026.9e6b.d87b
access-list rate-limit 102 0003.7f8e.a82d
access-list rate-limit 103 e0cb.4e54.82bf
on WAN facing interface i have the commands:
rate-limit input access-group rate-limit 101 16000 30000 35000 conform-action transmit exceed-action drop
rate-limit input access-group rate-limit 102 16000 30000 35000 conform-action transmit exceed-action drop
rate-limit input access-group rate-limit 103 16000 30000 35000 conform-action transmit exceed-action drop
But with this none of the these 3 mac address are being rate-limited
any ideas?
Hello Sheldon,
You can try this.
you have already created ACL and put them in Access-group right
1. now create class-map and match these ACL in it.
2. then create one policy map and attach those class-maps in policy map
3. then apply these class map as service policy on your outer interface.
example
access-list rate-limit 101 0026.9e6b.d87b - this is ACL
rate-limit input access-group rate-limit 101 16000 30000 35000 conform-action transmit exceed-action drop - this is access-group
class-map match-any MACADDR_CLASSMAP
match access-group 101
policy-map MACADDR_POLICYMAP
class MACADDR_CLASSMAP
int fa0/1
duplex-full
speed 100
service-policy output/input MACADDR_POLICYMAP - direction is as per your design
by creating policy map you can combine several access-group on same interface.
Hope this helps.
Jigar
5 Replies 5
Jigar Dave
Level 3
Level 3
where have you applied access-group command on interface ( inside of interface or outside of interface), can you share config? that would help a lot.
- Jigar
Actually when looking up rate-limit command using mac address I found that it only accepts one entry, and if multiple entries are found as in my config only the first one works.  Since I have only 3 clients that I needed to reduce bandwidth I have given them a static binding then rate-limited by their IP address.
THanks for your help though.
Hello Sheldon,
You can try this.
example
int fa0/1
duplex-full
speed 100
Hope this helps.
Jigar
Hello Dave, I am about to to try this, in your example, to add all three mac addresses under the:
"class-map match-any MACADDR_CLASSMAP
match access-group 101"
would I do this to add remaining two
match access-group 102
match access-group 103
Yes, you can, please try and let us know the results.
- Jigar
