rcv-err on a cat6500
grodoni
on a 6500 we have input error due to rvc-err (internal Rx buffer full ?).
- what rcv-err means exaclty ?
- rcv-err are problably due to
broadcast storm. How to avoid this ?
(for ex. by limiting broadcast
storm, ...)
Here the sh int and sh int counters err
TenGigabitEthernet3/1 is up, line protocol is up (connected)
Hardware is C6k 10000Mb 802.3, address is 0011.933b.45fc (bia 0011.933b.45fc)
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
Full-duplex, 10Gb/s
input flow-control is desired, output flow-control is on
Last input 00:00:34, output 00:00:10, output hang never
Last clearing of "show interface" counters 6d02h
Input queue: 0/2000/17585/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 8580000 bits/sec, 1900 packets/sec
5 minute output rate 2691000 bits/sec, 1471 packets/sec
717910461 packets input, 357404536454 bytes, 0 no buffer
Received 7933047 broadcasts (716416 multicast)
17585 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
1474892779 packets output, 1745705861196 bytes, 0 underruns
switch>sh int ten 3/1 counters errors
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize OutDiscards
Te3/1 0 0 0 17595 0 0
Port Single-Col Multi-Col Late-Col Excess-Col Carri-Sen Runts Giant
s
Te3/1 0 0 0 0 0 0
Port SQETest-Err Deferred-Tx IntMacTx-Err IntMacRx-Err Symbol-Err
Te3/1 0 0 0 0 0
switch>sh int gig 4/10 counters errors
Gi4/10 0 0 0 17597 0 0
s
Gi4/10 0 0 0 0 0 0
Gi4/10 0 0 0 0 0
thomas.chen
Level 6
Level 6
Rcv Error - This is an indication of excessive output rates of traffic. This is also an indication of the receive buffer being full. This counter should be zero unless there is excessive traffic through the switch. In some switches, the Out-Lost counter has a direct correlation to the Rcv-Err. This could be a sign that the segment is running at an inferior speed and/or duplex, or there is too much traffic going through the port. The first step in troubleshooting Out-Lost increments is to verify the link partner is running 100 Mbps, full-duplex without any errors. You can check the following link for more information on troubleshooting :
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00800a7af0.shtml
sayala
You may also want to check if you are not running into a bug where the rcvr error are not showing up under counter. "show interfaces counters [errors | etherchannel | {module number} | {trunk [module number]}] " lists details about the port in greater detail.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfd6.shtml#
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/12_1e/comref/show1.htm#wp2017656
You may also want to look at the number of drops on your input queue.
Input queue - The number of packets in the input queue. Size/max/drops = the current number of frames in the queue / the max number of frames the queue can hold before it must start dropping frames / the actual number of frames dropped because the max queue size was exceeded. Flushes is used to count Selective Packet Discard (SPD) drops on the the Catalyst 6000 Series running Cisco IOS. (The flushes counter may be used but never increments on the Catalyst 4000 Series running Cisco IOS.) SPD is a mechanism that quickly drops low priority packets when the CPU is overloaded in order to save some processing capacity for high priority packets.
