Routing Question - CEF
js358
Hello All:
Have 3 T1's that we planned using cef per packet but it kills our application.
Disabled it and now configured for per destination. I am a little confused about something.
I have 10.0.3.1 as the gateway for my clients. This interface - ip nat inside.
Have all clients statically mapped out
I have several questions. IP CEF per destination should make these T1's behave a seperate T1's correct. What I mean is....in order to get traffic to route out ANY of the 3 serial interfaces I have the follwoing in my config....is this correct? If not can someone point out the mistake....thanks
ip route 0.0.0.0 0.0.0.0 ser0/0
ip route 0.0.0.0 0.0.0.0 ser0/1
ip route 0.0.0.0 0.0.0.0 ser0/2
FA0/0 - 10.0.3.1 ip nat inside
ser0/0 - ip nat outside
ser0/1 - ip nat outside
ser0/2 - ip nat outside
By doing this, traffic can route out any T1 correct?
Harold Ritter
This configuration looks correct indeed. Configuring per-destination loadsharing will cause the egress interface to be selected based on hashing the source and destination IP address. If you want to determine what interface will be used for a particular source, destination pair, use the "sh ip cef exact-route .
Hope this helps
Harold Ritter
Hope this helps
Thanks alot, wasn't quite sure if I had it right.
