Error: Unexpected NM Interrupt received from slot: 0
sb.singh.hcl
In my cisco 2821 router following error occurs continously.....Please give me solution.
paolo bevilacqua
What do you have in slot0?
When reporting problem you must include full information.
sb.singh.hcl
in router 2821 no serial interface no bri port after booting give this massage
System Bootstrap, Version 12.4(13r)T6, RELEASE SOFTWARE (fc1)
Copyright (c) 2008 by cisco Systems, Inc.
Initializing memory for ECC
c2821 platform with 524288 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x18425ac
Self decompressing the image : #################################################
########### [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
000000           UNKNOWN port adapter
                0X000021B8 Onboard USB
                0X002C29F0 public buffer pools
                0X00211000 public particle pools
TOTAL:          0X004D5BA8
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 6Mb.
Using 1 percent iomem. [6Mb/512Mb]
**** WARNING ** WARNING ** WARNING ****
HW Revision could not be read from cookie.
Router may not function correctly.
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(15)T, RELEASE
SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 25-Jun-07 22:11 by prod_rel_team
Image text-base: 0x400A925C, data-base: 0x419EE180
%Software-forced reload
Seems faulty hardware.
