RE: Configuration of FFTH for Cisco 1841 Router
weiherd79
Hello Good Day,
I need help those who success configure ffth for Cisco 1841 router
I saw the post from below link
http://unifi.athena.my/config/cisco1841.txt
I did follow it but no luck to get connected, below are my configuration
Building configuration...
Current configuration : 5138 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname cisco1841
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
no aaa new-model
clock timezone PCTime 8
no ip source-route
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip bootp server
ip name-server 202.188.0.133
ip name-server 202.188.1.5
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ES_LAN$$FW_INSIDE$$ETH-LAN$
ip address 10.10.10.150 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
duplex auto
speed auto
interface FastEthernet0/1
description $ETH-WAN$
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet0/1.500
encapsulation dot1Q 500
pppoe enable group global
no cdp enable
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname username@unifi
ppp chap password pass123
ppp pap sent-username username@unifi password pass123
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
logging trap debugging
access-list 1 permit 10.10.10.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
login local
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 4000 1000
end
the router need to connect the port at BTU HG850a which is belong to vlan 500
thanks
weiherd79
the problem solved after use "T" IOS
c1841-ipbasek9-mz.124-24.T.bin
