Re-Enable Console in NPE-G2
arun.stha
How can I enable Console port in 7206 vxr with NPE-G2 card installed, I need to use console from NPE G2 card.
The device turns on and status is also UP and I can also telnet to the device but I am not able to access the device through console port...
Please Help.....
arun.stha
It is solved by using reset button which with reset the bit for console...
